Old 12-05-2023, 08:54 PM   #13 (permalink)
cRiPpLe_rOoStEr
Originally Posted by BlackGold6.4 View Post
I remember them installing a vaporizer with different spark plugs and bunch of work but mostly saving huge on fuel because I was a courier driver back then.
There is no vaporizer for CNG, as it's already stored at vapor phase, yet often there is a pressure reducer because it's stored around 3000-3600 PSI, while propane is stored at a much lower pressure (which I don't remember right now but it's noticeably lower). However, while pressurized, propane is at liquid phase, so when it's either left to de-pressurize or heated (through a heat exchanger connected to the coolant circuit, after the vehicle having been started on gasoline) it switches to vapour phase.
I wouldn't mind if you explained the difference between CNG and the others so it can clear the mud in my mind.
CNG main component is methane.
