Originally Posted by cRiPpLe_rOoStEr
There is no vaporizer for CNG, as it's already stored at vapor phase, yet often there is a pressure reducer because it's stored around 3000-3600 PSI, while propane is stored at a much lower pressure (which I don't remember right now but it's noticeably lower). However, while pressurized, propane is at liquid phase, so when it's either left to de-pressurize or heated (through a heat exchanger connected to the coolant circuit, after the vehicle having been started on gasoline) it switches to vapour phase.
CNG main component is methane.
Ok .. I see, right on and thank you.
