I also recommend bump starting your car, though I have only been doing it for a short while, it does save a significant amount of additional wear on the starter. There is only a marginal amount of wear added to the transmission if you use the highest gear to bump start, I find that any speed above 20 MPH use 5th gear, any slower and you may have to use 4th or even 3rd.
American by right
Ecomodder by choice
Hypermiler by necessity
