When running with traffic at a set speed, a lot of the air that you would normally push at higher speeds has been dissipated by the other vehicles going through the same space, when that happens, a lot of the pressure has been reduced (think tailwind pushing your car forward).
I am sure some of the more technical gurus can explain this better!
