Old 12-17-2023, 12:44 PM   #20 (permalink)
freebeard
It seem like I will not find 3D flow simulators help here, but what can be a first ''accessible'' book to read about vehicle aerodynamic?
As you say, the perfect is the enemy of the good.
If you were asking about help with CFD, that wasn't clear. There are threads here on the subject, and a Search field in upper left. If you want to read books, then search for Julian Edgar.
ecomodder.com/forum/showthread.php/new-amateur-aerodynamics-book
New amateur aerodynamics book
Hello everyone - I have been given permission by the webmaster to spruik* my new book.
It's called the Amateur Car Aerodynamics Sourcebook.
Amazon have it on opening special at the moment - see Amazon.com: Amateur Car Aerodynamics Sourcebook: For everyone interested in road car aerodynamics (9781482735253): Julian Edgar: Books
The blurb says:
At last – a book for those who like to modify the aerodynamics of their road cars!
In this book author Julian Edgar explores a host of practical and low-cost techniques that you can do yourself without spending a lot of money or needing special facilities.
Section 1 introduces aerodynamic drag and lift. The language is simple and straightforward – but still includes concepts such as drag co-efficients, lift co-efficients and the different types of drag that affect road cars.
Section 2 is devoted to aerodynamic testing – directly measuring aerodynamic pressures, and seeing airflow patterns by the use of on-road wool-tuft testing.
Section 3, the largest part in the book, covers aerodynamic modification. Fitting vortex generators, testing different undertrays, reducing drag, using turning vanes in intercooler ducting – all are covered in detail. In addition, techniques are described for reducing wind noise, building an effective engine intake that breathes high-pressure cold air, siting bonnet vents in the correct location, and testing airflow through intercoolers.
With nearly 300 full-colour photos and diagrams, this book is practical and down to earth – and uses techniques able to be carried out on the road.
Else you could just take the profile you've drawn, maximize the tumblehome and radius the edge to 3-4" and be done.
*I have no idea what spruik means.
