Originally Posted by Phase
I got thick fire fiberglass insulation and the. Covered it with aluminum bubble insulation RV people use on their windows and then sealed and taped it shut.
Do you know what kind of aluminum bubble insulation you used, or what its temperature rating is? I looked into using this type of insulation before, but the stuff I found is only rated for temperatures up to 180 °F.
