Old 10-24-2008, 05:17 PM   #11 (permalink)
eco_generator
AeroGuy
eco_generator's Avatar
Outback 14 - '14 Subaru Outback Limited
90 day: 23.1 mpg (US)
If you have have an OBD-I car, you need the appropriate Select Monitor to see for sure.
If you have a straight through or loud exhaust you can usually tell, the burble of the engine changes when the injectors are off or on.
I am under the impression that maybe besides some rare cars, that most should have some sort of fuel cut-off on deceleration. I have a SPFI engine in a 1989 Subaru GL that does the fuel cut off. In Subarus the fuel cut-off stops around 1750-2000 rpm from what I have seen. But even then, it is using less injector pulse width than in neutral. YMMV.
