Old 12-29-2023, 02:56 AM   #857 (permalink)
cRiPpLe_rOoStEr
That is directly related to ever increasing fuel economy and emission standards. combined with consumer expectations.
Safety standards also have their share on this issue. Otherwise, Americans would've had the chance to buy a Kia Pregio in 2004 for instance.
You mentioned a dislike of turbos in a post above but naturally aspirated engines are also complicated. Stop/Start, variable valve timing, cylinder deactivation.
I'm well aware not only about Argentinians replacing a port-injection setup for a carburettor as a makeshift fix in simpler old-school engines, but also replacing a more complex one for whichever would be better suited to the carburettor trick.
An old school simple NA 4 cylinder simply cannot deliver the driving experience that drivers want and the fuel economy / emissions that automakers are required to deliver.
Odd enough, until some years ago, some folks still got the approval at the technical inspection in Argentina, in cars adapted with a carburettor to replace the EFI. Sure there were some comprimises regarding performance...
