Old 01-03-2024, 12:23 PM   #19 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
here are some numbers I pencil-whipped for the Chevy BOLT I'll be getting in September.
I used Cd 0.31, Af 25.7-sq-ft, 0.00238 slugs air density, and 3,880-lb test weight.
Aerodynamic horsepower requirements are presented in 5-mph increments, from zero-to 100-mph:
0-mph = 0
5-mph = 0.0067
10-mph = 0.054
15-mph = 0.183
20-mph = 0.435
25-mph = 0.8497
30-mph = 1.4683
35-mph = 2.3316
40-mph = 3.4805
45-mph = 4.9557
50-mph = 6.7979
55-mph = 9.048
60-mph = 11.7468
65-mph = 14.9351
70-mph = 18.6535
75-mph = 22.943
80-mph = 27.8444
85-mph = 33.3983
90-mph = 39.6456
95-mph = 46.6371
100-mph = 54.3836
Over the same speed spread, power absorbed from rolling-resistance increased linearly, from zero, to 8.9873-hp ( using a Cfrr of 0.008686291 ( probably 'high' )) [ Bridgestone Ecopia is around 0.005 ].
If everyone constructs one of these tables from 'day one', 'curves' can be constructed from the data-plots for aero and R-R, plus adjustment for mechanical efficiency, and presuming a constant BSFC, or BSFC-e for BEVs, one can predict, at any chosen velocity, what mpg, or 'range' their vehicle will return.
With EV's the speed has a greater effect on range since the efficiency of the motor doesn't go down so much at lower speeds.
I remember when I had the Nissan Leaf that someone had done the work to figure out what speed would give the Leaf the greatest range, and it was 12mph.
I would sometimes start a long trip creeping along at 25mph which would give me quite a range advantage, sometimes getting over 100 miles with juice to spare in an EV that had an advertised range of 71 miles at that point.
The Following User Says Thank You to Isaac Zachary For This Useful Post:
aerohead (01-03-2024)
