Old 10-24-2008, 11:53 PM   #37 (permalink)
red91sit
MarzyPan - '95 Honda Civic 2000 Si Running Gear
Originally Posted by Duffman View Post
What cylinder deactivation is doing in the simplest theoretical terms is redirecting the air from one bank to the other since the engine still requires the same amount of power to go down the road. The increased load on one bank reduces that sides pumping losses, since the other bank is not moving any air there is no pumping losses other than heating up the air that always stays in those deactivated cylinders. Theres no messing with O2 sensors AFAIK because there is either no flow over them or the flow doesnt change depending on where they are located.
As far as the heat goes, it only increases in heat under compression, under decompression it absorbs a lot of that heat back into the gas (air).
