Old 01-09-2024, 11:24 AM   #211 (permalink)
Piotrsko
Comments: unsure if containing water will ever ecceed the psi limits of any aircraft fabric, but you also put holes to let that water out. I do know that screaming through a water puddle cannot distribute the loads sufficiently enough to preclude failure. Water is rather like a brick wall at high speeds.
There were WW2 and beyond aircraft that had fabric moveable control surfaces.
sregord (01-22-2024)
