Old 01-10-2024, 01:59 AM   #212 (permalink)
j-c-c
A client has a 55-foot Prevost motorhome.
* 'Chord' = 55' ( 16.764-meters )
* 'Wingspan' = 8.5' ( 2.59-meters )
* 'Aspect ratio' = 0.154
* 'Wing area' = 467.5 square-feet gross ( 43.432-sq-meters ) [ we can ignore the wheel house areas for simplicity ]
A cubic-foot is 12-inches on a side, with 1728- cubic-inches volume.
A cubic-foot of 60-degree F water weighs 64.2-pounds.
There are 7.707- gallons in a cubic-foot of water.
Each gallon of that same water weighs essentially 8.33-pounds.
A one-inch 'slice' of a cubic foot of water weighs 5.35-pounds.
One square foot contains 144-square-inches.
One square-inch of water, one-inch 'deep' weighs 0.0578-pounds.
The World War-II, Waco Aircraft Co. CG - 4G 'Hadrian' assault glider, ( featured in 'Saving Private Ryan )' is cloth-covered, reaching up to 150-mph ( 241.4 km/h ) while towed behind the Douglas C-47, 'Skytrain', then glides to it's target landing zone at around 75-mph ( 120.7 km/h ).
The cloth-covered wings have a design wing loading of 8.33-pounds per square-foot.
A 'cloth'-skinned belly pan, built to the specification of the Hadrian's wing would support 8.33-pounds per square-foot, at normal loading.
8.33-pounds per square-foot requires a live-load of 1.557-inches of standing water, netting 3,894-pounds of water on top of the pan.
If the Hadrian is designed to a 4g safety factor, positive and negative, then specifications would allow a survivable depth of 6.22-inches of standing water on 'top' of the belly's membrane, still short of structural failure, be it the membrane, ribs, stringers, or 'wing spar'; yielding a live-load of 15,577-pounds of standing water without failure.
I'm not advocating for allowing 'any' water to make its way onto the top of any belly pan, regardless of materials chosen.
The wheel-houses and inner fender wells will be the focus, as this is where splash and spray originate.
Most homes and apartments I've experienced have 'ceilings'.
And they're typically constructed with paper-sheathed gypsum board ( Sheetrock' if you will ).
And even though their complete and total destruction is just one, leaking roof away, we continue to construct them, while inspecting, and maintaining roof integrity.
Seems like a stretched-fabric membrane, securely fastened to it's supporting structure, could function reasonably well as a belly pan, as long as its weaknesses are respected in the 'build.'
I guess if we ignore concentrated ponding effects, constant turbulence/buffeting on both surfaces, repeated dynamic road induced unknown g shock loads, it should fly, so to speak.
The Following User Says Thank You to j-c-c For This Useful Post:
sregord (01-22-2024)
