Thread: DIY heat pump??
Old 10-25-2008, 10:41 AM   #30 (permalink)
Xringer
Old Retired R&D Dude
Little Red - '12 Toyota Prius c 2 Two
90 day: 57.82 mpg (US)
"Whitey" Bulger - '14 Toyota RAV4 LE
Originally Posted by theCase View Post
I wonder how a reverse AC unit would work if you had it facing the south, then enclosed the area along the house with a clear plastic lean-to with the ends open. It could raise the ambient temp on a sunny day and provide a bit more efficiency. Maybe?
I've been thinking about that too. Add-on green houses or 'sun rooms' are
pretty nice heat sources when south-facing.
If you installed one using some good thermo-pane windows, and had the whole air-space well insulated, you could just pump the warm air into your home using a simple fan.
But, if you went with plain glass or plastic, you would need to get the air space up around 50 to get good results with the reverse AC unit..
The larger the air space, the better!
Cheers,
Rich
Current ride: 2014 RAV4 LE AWD (24 MPG)
Wife's Pizza Transporter
