Old 01-22-2024, 05:53 PM   #218 (permalink)
sregord
EcoModding DIY aer.or
You could experiment with 'tension', and determine how close you'd have to space support ribbing to maintain an acceptable level of 'sag' in between supports.
A local trim or upholstery shop would be able to sew in reinforcing strips with brass webbing eyelets, at any chosen location, which would allow you to lace the fabric onto your skeleton anywhere needed.
Sounds like a big trapeze.
I'm not advocating for allowing 'any' water to make its way onto the top of any belly pan, regardless of materials chosen.
The wheel-houses and inner fender wells will be the focus, as this is where splash and spray originate.
Seems like a stretched-fabric membrane, securely fastened to it's supporting structure, could function reasonably well as a belly pan, as long as its weaknesses are respected in the 'build.'
All, even aluminum sheet, would...should have some focus'd protection from the wheel wells, well secured leading edges that face especially forward, but also left, right & the rear and keeping it away from catalytic converter & other exhaust piping heat.
...as Piotrsko mentioned IF a "pond" were to develop, a first inspection drain hole?
One more thing to ponder is ease of drive-train maintenance.
The Following User Says Thank You to sregord For This Useful Post:
aerohead (01-25-2024)
