Old 02-10-2024, 11:23 AM   #4 (permalink)
aerohead
calculating for BOLT
Originally Posted by broski499 View Post
I registered every fill-up with my 2008 Prius for 10 years on this site.
I recently switched to a Chevy Bolt and am trying to figure out how I can register the energy use.
Do you calculate how far you went and then how much energy you used on the odomoter trips? Charging up resets it. So each fill up with whenever you charge?
Curious how some of you are going about this.
Member AeroStealth has a BOLT, and has posted all his MPG-e data at the 'Garage & Tools' Forum.
I believe that he uses his phone to photograph both the in-car energy display, plus his EVSE screen to capture all the numbers.And there's about a 10% in charging efficiency difference, between the 120-V 'Granny' charger, and a 220-V home charger, plus DC fast chargers.
