Good thinking, that's going to look great. If you get some black plastic, you could cut it to size for the opening between the guino and the clock housing, and it would look like the factory put it there themselves. You could even mount the lcd to the plastic and then mount the plastic to the clock housing. Might be a good bit easier. Good luck.
