Originally Posted by V6MustangFTW
Never heard of that before, good to know. I'm going to put resistors in their place so the car thinks they're still there and the airbag light goes away. Last I checked an airbag light is an instant state inspection fail here in Virginia, otherwise I wouldn't really care about the light.
Yes ... In VA the airbag light would cause a fail for state inspection .... other than resistors maybe a simple way would be to simply remove the ABS bulb? I was going to get "fancy" once and wire the airbag light into a circuit that lights when started but goes away after a few seconds (some inspectors are or may be savvy enough to actually look for the light to light up BUT I imagine most would not really pay attention to things unless they are still lit up after the engine is up and running .....
2003 Jetta TDI Wagon, 5 sp, 210K miles, Stock.....for now!
