Old 02-19-2024, 11:16 AM   #45 (permalink)
aerohead
' break downs '
Originally Posted by Phase View Post
Do you have any break downs on why the new Prius has so much higher drag coefficients than the previous models? Many casual people think it “ looks” the most aerodynamic of any prius but clearly it’s not
I’m just curious to what you’d say pops out to you visually
I went to TOYOTA's website for the 2024 Prius, and found some pertinent info to add to what we've talked about so far:
A) If the roof apex has been moved rearwards 2-inches, then Toyota has 'shortened' the roofline of the new car, a direct violation of aerodynamics writ large.
B) Even if the entire 1-inch lengthening of the new car is added to the rear, the roofline is still 'stunted.' It's more 'bluff.'
C) The rocker panels on the new car are 'mutilated' by the designer's horizontal character line embossed into the sheet metal, creating a pressure 'kink.' Another violation of 'aerodynamics'
D) The new car body has been widened in the rear, adding 'haunches' for 'stance', and in so doing, destroyed some of the car's facility for pressure recovery; the most important thing with 'aerodynamics.'
E) Both the 17" and 19" tires are P195s, so the frontal areas are identical, and no potential for a difference in drag there.
BIG NEWS!
F) The Prius SE is the 'ONLY' Prius with Cd 0.27.
G) The Prius Limited & XSE are Cd 0.29.
H) The non-SE cars are 'taller' ( greater ground clearance ), exposing 0.4-inches more tire face to the air.
I) The non-SE cars are 'wider'.
J) Their CdAs are greater
K) Although the new car is reported to be 1-inch greater in length ( 181.1" ), the out-going Prius is 182.9" in length.
L) The engine in the new Prius has an identical 'Brake Thermal Efficiency' ( BTE ) as the out-going model.
Without a set of blue-prints for the cars, I'm hamstrung, and can't say anything definitive, aerodynamically.
