Old 03-06-2024, 03:59 PM   #1 (permalink)
mpEg_build
Ecomodding Lurker King
mpEg_build's Avatar
EG boi - '94 Honda Civic VX
Spooly boi - '06 Mitsubishi Lancer Evolution 9 MR
Drifty boi - '89 Nissan 240sx S13
D16y5 swapped EG vx
Hey guys! I plan on "retiring" my EG hatch from racing and get it back to fuel sipping. So I'm getting rid of the LSVTEC setup as they call it and swap a d16y5 with matching trans on the car.
Basic rundown on what will be done
-d16y5 refresh (gaskets and timing belt etc)
-d16y5 and trans swap
-lightened flywheel
-retain b-series mounts
-plug in Rywire tuck harness (obd1)
-run Federal VX ECU
-Maybe try to get a tune with my other hondata chipped ecu?
-run mpguino I had tucked for years
-aero and weight reduction mods
Feel free to chime in what other things I can do to hit good mpg numbers. Only thing is I plan on making it still look good while getting good mpg numbers like these guys.
Cheers!
ID:	34568   Click image for larger version
ID:	34569   Click image for larger version
ID:	34570   Click image for larger version
Function >= Form
The Following User Says Thank You to mpEg_build For This Useful Post:
Ecky (03-08-2024)
