Old 03-09-2024, 11:38 AM   #6 (permalink)
aerohead
' Exterior dimensions from 1:18th-scale die cast model '
Browsing online, I came across a die-cast 1/18-scale model for the GAC TIME concept. which provided scale length, width, and height centimeter measurements.
Multiplying by 18 yields full-scale:
L= 5490mm
W= 1980mm
H=1386mm
h=1253.8mm ( approx. by measuring side elevation image )
GC=132.1mm ( by same technique )
Forebody= 49.1%-L ( by ditto )
Aft-body= 50.9%-L ( by ditto )
Verjungungsverhaltnis = 2.052 ( ditto )
Gross frontal area = 29.538936 sq-ft ( 2.744257 meters-sq )
The exterior dimensions for the Cd 0.19, 2016 M-B IAA, of which the 'TIME' appears quite similar, are available online for comparison.
They're not 'clones' of one another, but do share geometric similarities.
