Old 03-13-2024, 03:32 AM   #12 (permalink)
Paulbstockton6@hotmail.co
Murry... this post is seven years old...you'll likely not get an answer from those in that discussion.
I'd suggest trying ToyotaNation.com and a search there ( only for belt size....
But, if you can remove the belt, estimate how much shorter you need it and "guess". As long as you keep the belt clean most part places will accept a return, or you could tell the parts guy you want to try one 4" shorter and try again
And, don't worry about any of the other details, i.e. removing the hoses, looping the hoses, etc...
