Old 03-27-2024, 02:01 AM   #7 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
If you never want to use the A/C, you can remove the compressor clutch fuse or relay. Then you can set the temp knob all the way down without the A/C kicking on. If the A/C pulley is easily visible, you can look at it with the temp knob at different settings to see if the A/C compressor is actually turning on.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
