Thread: 2019 Chevy BOLT
Old 03-29-2024, 03:30 PM   #14 (permalink)
redpoint5
90 day: 29.78 mpg (US)
Your Bolt is capped at a 55 kW charge rate so even the older 50 kW chargers will work fine for you.
The rate begins to taper around 50% if I recall correctly, and becomes nearly pointless to continue charging after about 80%, unless that extra bit of range is a requirement to get to the next location.
I drove an hour down to a Walmart in the path of totality and then drove back after.
Salem Walmart? I'd have invited you to the farm. We had maybe 30 people there, half of which I'd never met before.
