Old 01-25-2008, 04:38 PM   #10 (permalink)
Chris D.
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
Originally Posted by TomO View Post
Don't forget to change your antifreeze concentration. In MN here, you want at least a 50/50 mix or for winter most people will run a 70/30 mix, 70% glycol, 30% water.
With you having a 2wd truck and not used to driving in snow & ice, I would heartily agree on getting the snow tires.
Just make sure that your truck is tuned up and ready. Living in MN isn't as bad as other people make it out to be. I have a friend that moved here from Cali and he has acclimated to life here in just over two years. His vehicles faired well through the transition too.
I'm orignally from Coon Rapids off of Hansen Blvd.
I'n my other 2wd pickups I had when there I usually kept about 300lbs in the bed for traction and all season radials and never had problems with that setup..
But that truck was prepped for winter by its previous owner..
front and rear winch, block heater, underside coating, autostart, ect..
My vehicle is virgin California sheet metal so i figure I better get a jump on things.. I've even considered having the underside bedlined lol
