Old 04-05-2024, 12:58 AM   #13 (permalink)
S Keith
Originally Posted by Isaac Zachary View Post
That could possibly be the problem. But since there's no red triangle, and I'm not sure if the red triangle light even works, I guess I could try to connect with the Torque app to see if another module has failed.
However, a bad HV battery usually will still start the car, at least after unplugging the 12V and trying again. But I get zero response. The only thing that displays on the dash is the open door symbol.
Sound like your combo meter has failed. When combo meter fails, master warning, CEL, etc., don't work.
There are certain faults that will be immediately detected at power on.
Sitting for 3 years has almost certainly driven at least ONE of the 14 blocks to measure below 12V. The car will not start with a block lower than 12V.
I would see what Torque says and/or Hybrid Assistant if on Android.
The Following User Says Thank You to S Keith For This Useful Post:
MetroMPG (04-29-2024)
