Old 04-08-2024, 01:53 PM   #78 (permalink)
LostinTransit
Old But New Ecomodder
LostinTransit's Avatar
After we had the EGR valve replaced I've learn more about our van. it's clear that within the specs it says can run regular fuel and the e85 fuel.. so starting this weekend.. I'll be readjusting to running the efuels.. the reasoning here is after seeing both ports in the EGR caked up with carbon.. I suspect the efuels will attempt to clean out the engine. Though we'll suffer with fuel economy,.. the performance aspect will be greatly increased. one thing to is that because we removed the slat on the active shutter system.. I would if running the efules will make any difference. So now knowing I can run the efuels.. I'm looking forward to it once again. just have to be careful not to just top off the tank with 10.00 I need to wait till at least less than half a tank.
