Old 04-10-2024, 02:37 AM   #21 (permalink)
S Keith
Originally Posted by Isaac Zachary View Post
I know. I was trying to buy inopperable Prii for spare parts (make one car out of two) and couldn't get one for a reasonable price. I should have sold it then, back when it still ran and the 1) dash, 2) heater, 3) A/C and 4) infotainment all worked. I just don't understand why they have stopped one by one.
Because these are common failures of the Gen2.
1: Combo meter. Extremely common failure. $150 DIY fix.
2: Likely the blend door actuator. Cheap part but a real pain to replace. ~$50 DIY fix
3: Every Gen2 I've owned (7) has a leaky A/C system that needs occasional recharging (along with 100s I've serviced). One needed a replacement compressor. $20 hose and $10/can of SuperTech R-134a.
4: If you mean touch screen - another very common failure. $299 @ autobeyours.
Others include the inverter coolant pump ($150), coolant control valve ($125), hybrid battery ($1950 list) and ABS actuator (about $1200 online discount dealer - BIG DIY job).
The Following 2 Users Say Thank You to S Keith For This Useful Post:
Isaac Zachary (04-14-2024), MetroMPG (04-29-2024)
