Thread: 2019 Chevy BOLT
Old 04-11-2024, 11:41 AM   #30 (permalink)
redpoint5
90 day: 29.78 mpg (US)
Is $20k in repairs an annual budget, cause that's a ton of money. Seems you could replace the charging cable every month and spend less than $20k per year, so why is it so expensive?
That's the big problem with DCFC, that it has no path towards sustainability. If consumers paid the actual cost to install and operate them, they'd probably be paying $2/kWh, in which case rational people would just drive an ICE.
My prior research found that chargers need to be utilized 8hrs per day to break even on cost, and that's for the cheap 50kW units. Higher output units cost more to install, cost more in demand charges, and require even higher levels of utilization to break even on cost.
aerohead (04-11-2024)
