I'm not a fan. I'd imagine they do work to some extent, but they're also a fire risk if you wind up with any sort of oil leak. Usually minor leaks will not result in a fire and you have ample time to fix them, but a blanket can both conceal the leak and absorb enough oil to make it a big problem.
