Old 04-14-2024, 04:30 PM   #25 (permalink)
S Keith
Originally Posted by Isaac Zachary View Post
I try to start it once a month and floor it with the brake pedal depressed while in drive in order to fully charge the HV battery. But what is happening seems to act like there's no key, 12V is charged, door ajar light comes on, but key in socket and the on button does nothing, with or without the brake pedal depressed.
Fuse box under hood. One down from top right - check the AM2 fuse.
I meant I can't get the heater or A/C to turn on because the touch screen is not working. The blend door is probably fine. Who knows about the A/C, it never gets hot enough around here to need it.
A/C can be engaged from the steering wheel buttons. If steering wheel buttons don't work, you also have a failed clock spring - very common.
The Following User Says Thank You to S Keith For This Useful Post:
Isaac Zachary (04-14-2024)
