Old 04-15-2024, 01:47 PM   #28 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
Originally Posted by S Keith View Post
Fuse box under hood. One down from top right - check the AM2 fuse.
A/C can be engaged from the steering wheel buttons. If steering wheel buttons don't work, you also have a failed clock spring - very common.
I checked the AM2 fuse. As you suspected it was blown.
I replaced it and tried starting the car. Dash lights came on and it seemed like it was going to start.
Looking at Google it could be an inverter cooling pump short circuit. But this was replaced at the dealer less than 100 miles ago.
About 5 seconds later the dash went black again with only the door ajar light on. I tried restarting, which was a no-go. I checked the new AM2 fuse and found that it too was again blown.
