Old 04-15-2024, 01:53 PM   #29 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
Originally Posted by S Keith View Post
Fuse box under hood. One down from top right - check the AM2 fuse.
A/C can be engaged from the steering wheel buttons. If steering wheel buttons don't work, you also have a failed clock spring - very common.
I checked the AM2 fuse. As you suspected it was blown.
I replaced it and tried starting the car. Dash lights came on and it seemed like it was going to start.
About 5 seconds later the dash went black again with only the door ajar light on. I tried restarting, which was a no-go. I checked the new AM2 fuse and found that it too was again blown.
The inverter pump was replaced less than 300 miles ago at the dealership.
