Originally Posted by Isaac Zachary
I checked the AM2 fuse. As you suspected it was blown.
I replaced it and tried starting the car. Dash lights came on and it seemed like it was going to start.
About 5 seconds later the dash went black again with only the door ajar light on. I tried restarting, which was a no-go. I checked the new AM2 fuse and found that it too was again blown.
The inverter pump was replaced less than 300 miles ago at the dealership.
Either it has failed again in short, or you have another short elsewhere.
Disconnect this plug:
Replace the fuse. If the fuse blows again, you have a short elsewhere. If it does not blow, the pump is likely shorted.
Given that the car has been sitting awhile, there is a risk that critters have chewed wires.
