Old 04-16-2024, 02:53 PM   #38 (permalink)
j-c-c
Here is a well-done teardrop.
With a monocoque box on a flexible subframe, the Model 560 shape follows Wally Byam's pre-Airstream teardrop.
Routing the side panels for wiring runs under an aluminum skin could work with a foamie.
I like the wire routing solution, except it is a huge stress riser in a monocoque structure. that rests on an admittedly flexible sub frame.
The Following User Says Thank You to j-c-c For This Useful Post:
freebeard (04-16-2024)
