Thread: Oilgate
Old 04-19-2024, 11:33 PM   #9 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
I'll have to see if my dad's Craftsman hydrostatic drive oil can be changed. I suppose one could drill and tap to add their own plug.
My dad is a fixer, so if the frame started cracking, he'd get the welder out.
You could do that but you would want to pull the lower case before doing it. Aluminum chips would do a number of the center case surface of a hydrostat. Change the oil filter while you have it apart.
For the John Deere you had to pull the transmission and flip it upside down to change the oil. (Of course you could then add drain holes / plugs)
Rule of thumb was to change the oil at 50 hours and then every 200 after that.
