Old 04-29-2024, 12:57 PM   #22 (permalink)
aerohead
' albedo '
Here is a metamaterials approach:
A self-assembling aluminum foam. I should think that would be fairly durable.
Since there is a sintering phase to the process I doubt it will be made into a paint.
1) I'm not seeing much daylight between this 'breakthrough' and flat white, titanium dioxide-based pigments.
2) Secondly, I see no discussion of 'latent' heat, which is typically the reason behind refrigerated air conditioning.
3)' Cooling' the inside of a home can 'kill' you, if you don't 'dehumidify' the air volume ( at high dewpoints, you could produce condensation on every internal surface of the living space, triggering 'black-mold') ).
4) The temperature of a roof and it's radiative load, downwards through an attic space can have 'zero' effect on the cost of cooling.
