Old 05-02-2024, 06:31 PM   #27 (permalink)
freebeard
While you think in terms of conventional attics, I think in terms of geodesic dome, with minimal material composition. Like aluminum plating weather shell with a tensioned fabric or foil inner shell.
Also I wonder whether the foamed aluminum can pass air or Nitrogen gases. If so it might be an ideal material to cast nose cones for atmospheric reentry.
edit:
To be clear, the space between the inner and outer shell replaces the attic. But it's a dynamic system (down on the shady side, up on the sunny side) instead of a stagnant pool. Don't get me started on engineered roofing trusses.
You can't be wise and in love at the same time. -- Bob Dylan
aerohead (05-09-2024)
