Old 05-08-2024, 03:12 AM   #13 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I assume you tried new spark plugs, but I don't see it mentioned. Kinda sounds like an ignition issue to me. Looks like you've replaced the rest.
Try swapping injectors? Crank it with the fuel pump relay or fuse pulled out to relieve pressure first.
Try swapping the ECM? If it's accessible and doesn't contain an immobilizer, it might be an easy thing to try. Honda ECMs rarely go bad, but it's possible.
Engine grounds good?
Check fuel pressure?
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
