Teardrops don't have edges?
Only a 'half-body', based on a 'teardrop' ( streamline body of revolution ) would have 'edges'; at its lower interface with the underbody.
The ' 4% ' radii may be from Hucho's reporting on the R&D of the Volkswagen Vanagon, for which they discovered that forebody drag reduction hit 'saturation' with leading edge radii = 4% of body width.
Any additional 'softening' of the corners was rewarded with 'zero' additional drag reduction, hence 'saturated.'
On 'trailers', some use the square-root of the frontal area to use in the calculation, instead of width or height ( they're just creating an 'square -rectangular' cylinder of equal height and width, to simplify an averaging dimension ).
I use it in the dimensional analysis of each vehicle, reducing them to a rectangular cylinder, for which to create the bar-graph from which the comparisons can simply be made.
( the one car associated with the 'shortest' cylinder, compared to all of those from those associated with the same drag coefficient, is, by 'default', the 'optimum' , most 'efficient' body shape for the entire field.
It would be your 'template' for modifications.
