Old 06-10-2024, 11:57 AM   #229 (permalink)
freebeard
Call it Meredith Effect then?
Many recycling centers no longer allow any material to be recovered and purchased, and this may be the 'end' of accessing used structural light metal for me.
That's really sad, local to me BRING recycling is flooded with diamond plate and architectural aluminum sheets in 4x4ft and larger sizes. Priced in the hundreds of dollars.
I just scored three 10ft corrugated steel sheets that have holes around the edges but none through the field so new you can see the Zinc crystals on the underside. $24 each, and I'm going to try spot welding two sheets together to reroof the breezeway.
You can't be wise and in love at the same time. -- Bob Dylan
Last edited by freebeard; 06-10-2024 at 12:53 PM.. Reason: 'together' for 'togeter'
aerohead (06-13-2024)
