Old 06-15-2024, 10:07 AM   #241 (permalink)
Piotrsko
Originally Posted by j-c-c View Post
Not sure anyone was discussing anything being fireproof. My point was aluminum is on the lower end of the temperature achievable destruction range I suspect in typical automotive fire environments, and alum will contribute/self-sacrifice quite actively when that temp is reached.
Again:
Aluminum doesnt burn, it melts. Ditto for steel which may experience a heat transfer to something flammable if it has enough surface to oxidise that rapidly.
Your point as contrary to your previous statements:
"Additionally, many seem to ignore, aluminum is quite flammable if the needed temp it is exposed to can be reached,"
