Old 06-15-2024, 06:31 PM   #12 (permalink)
freebeard
I asked it to summarize #8:
No mention of that carefully constructed persona. How does the wife feel about you obsessing over someone else?
The article suggests pop-up campers can be further improved for aerodynamics, and mentions consulting Ecomodder for DIY modifications if you're handy with tools.
This design was released under a Creative Commons copyleft. Tandem small wheels to reduce frontal area. and provide redundancy. It ticks all these boxes.
Balance size and shape:
Kammback design for trailers:
Minimizing frontal area:
One might add this to the rear:
A door in the Kammback and a fold-down step that doubles as a leveling jack. Like this but faster backwards (and fewer seams and rivets):
Here's the chassis, same as my 1952 Silver Streak. There's a carriage bolt through the decking at each C-channel end:
________________
A place to poop is in the remit.
https://storage.googleapis.com/hippo...441ca1441d.jpg
_______________
Converting a car to a trailer maybe no bueno.
The axle winds up in the wrong place. The trailer can be a specific design, as this case of a pop-up:
The ultimate pop-out doubles the space, with a sliding three walls and roof, and a fold-down floor:
edit:
IIRC that was Tan Son Nhut Air Base. The French used wrought iron utility poles. The USofA used wooden poles with a service life of five years in that climate.
Instead of sliding, the pop-out could be on two four-bar linkages. Completely inaccessible when folded up.
________________
Because much of what is in the published literature is nonsense,
and much of what isn’t nonsense is not in the scientific literature.
-- Sabine Hossenfelder
