Old 06-15-2024, 09:56 PM   #15 (permalink)
freebeard
Faster when it's open? All that video and they don't show one opening or closing.
Folding hitch seems sketchy. In fact, ditch the whole Chinese frame and drop it onto a Beetle, New or Old with a Type III engine. Cut out the front wall and you'd have a Class-A motorhome.
edit:
Youtube followup: Be Totally Self Sufficient - You Can Camp in THIS Trailer Literally ANYWHERE on Earth!. Only $139K, this 'trailer's' wheels are optional. Deliverable by Zeppelin.
2nd edit:
https://www.greenbuildingadvisor.com › article › does-vacuum-insulation-make-sense
Does Vacuum Insulation Make Sense? - GreenBuildingAdvisor
The net result is that an inch-thick vacuum insulation panel can provide a center-of-panel insulating value of R-25 or even more — compared with R-6 to R-7 for standard rigid foam insulation. The "hardness" of a vacuum. The key property of a vacuum is its pressure, or how "hard" it is. We often
