Thread: Rear diffuser?
Old 06-23-2024, 04:54 PM   #105 (permalink)
freebeard
Is it possible to improve the rear of the chassis, e.g. the tank, spare wheel?
It's always possible. The question is would you like living with the result.
For instance, one might remove the spare tire well, put a 90 degree elbow ahead of the muffler and run it laterally behind that crossmember between the struts to exit on the other side.
Then you could ramp the diffuser from [ahead of] the crossmember itself.
