Old 07-02-2024, 09:30 AM   #36 (permalink)
Piotrsko
Use cases require cabling or places to put connectors. A PI 5 has the GPIO pins, but ethernet, USB, serial, parallel, need at least a half inch of case to install. If all you're doing is surfing the web, and letting the router handle the I/O, then all you need is power in. Have you tried a USB "C" to anything adapter lately? Theory says it's easey peasey, reality says different.
Isaac Zachary (07-02-2024)
