Thread: New Prius
Old 07-11-2024, 10:29 AM   #11 (permalink)
aerohead
'smaller' 'usually'
Originally Posted by Phase View Post
Smaller wheels usually give better mpg. Even Toyotas website and teslas websites show range and mpg being improved with smaller tires.
1) You, Wayne, and the Prius forum are not identifying any mechanisms which can be attributed to the alleged improvement in mpg. 'Smaller' wheels is meaningless unless you provide conditional specifics.
2) EPA HWY ratings are meaningless within the context of the 'real world.' This value is 'fudged' from data obtained in a way which is impossible for us, unless it's done in a test cell, on a dyno, exactly like EPA Mobile Sources does.
3) At 70-mph, I can get anywhere from 43-mpg, to 99-mpg in a Gen-2 Prius, 'depending' on 'conditions.' My neighbor, with the 2022 Prius saw up to 80-mpg between Denton, TX and Oshkosh, Wisconsin. These kinds of data have value 'ONLY' if all the accompanying conditions are captured for the event.
4) For your 'small wheel' argument you've introduced:
A) a frontal area unknown
B) a rolling force coefficient unknown
C) a polar moment of inertia unknown
D) a wheel offset unknown
E) a wheel-arch gap unknown
F) a wheel porosity ventilation drag unknown
That's six unknowns that aren't accounted for, and until they are, your just 'throwing ---- at the wall, and looking to see if anything sticks'.
You guys need to put your heads together, and get into the 'weeds'.
