Old 07-12-2024, 11:16 PM   #49 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
Originally Posted by JohnForde View Post
Zevo is not designed for trailering and the manual says do not tow. It will be technically difficult to get a 'pigtail' connector ($500?) but I will have to do it soon.
OTOH I will only need to do it when my WT extends more than 48" behind the step bumper, (59" behind the tail lights) so that is what I am working on with the plywood prototype.
If you put a second set of taillights on the back of your aero tail your angle issue goes away. They can be as simple or complex as you want to make them but your are compromising your aero trying to keep the stock taillights visible from the rear.
You could do something as simple as trailer lights on a swing out extension wired to a trailer pigtail. Plug them in when the tail is extended and remove them or fold them back when the tail is folded.
The Following 2 Users Say Thank You to JSH For This Useful Post:
freebeard (07-13-2024), JohnForde (07-28-2024)
