07-14-2024, 10:48 PM
#1565 (permalink)
I believe they modded the air inlets on the sides and put on old bug wheels.
For Fuchs sake.... https://www.heritagepartscentre.com/...loy-wheel.html
Lightweight and forged
However, the Porsche engineering team knew that a regular, cast alloy rim would not withstand the high loads imposed by a ‘serious’ sports car (without exceeding the all-important weight reduction etc). Otto Fuchs suggested that the solution would be to opt for a high-strength/lightweight forged-alloy wheel. The concept of a mass-produced, forged-alloy wheel was a radical idea back in the 1960s, but Otto Fuchs went on to design a whole new manufacturing technique to produce a one-piece wheel from a forged aluminium ‘blank’. Porsche designer, Heinrich Klie, was assigned the task of styling this new ‘Fuchs’ wheel, which he shaped and formed in modelling clay before presenting his design to Ferry Porsche in May of 1965.
58 steps to the perfect Fuchs...
Ochel went on to finalise the design/specs, and mapped out the 58-step process required to manufacture the one-piece wheel… (And yes, ‘58-steps’ made the Fuchs one of the most complex mass-produced wheels ever!). The manufacturing process began with a pressed section of high-grade aluminium stock, which was forged to produce a blank. Drop-forging this ‘blank’ punched the holes between the spokes and deburred the flange, while a secondary drop-forging process formed a split flange (which was then rolled-out/widened to complete the one-piece rim). This complex manufacturing process resulted in a wheel, which was ‘machine-formed/finished’ on the inner-/back- side, too (unlike a cast wheel, which would typically be ‘rough-cast’ on the inner side). In short, the high-quality, forged construction process resulted in an incredibly tough (yet light-weight) wheel, which was far better balanced ‘out of the box’ than a regular, cast wheel.
It's hard to discern but those look like Porsche center caps. The Type IIs have aftermarket reproductions with blank center caps.
