Old 07-25-2024, 10:27 AM   #76 (permalink)
aerohead
' 14-degrees '
Originally Posted by JohnForde View Post
I might be able to install these and try them Thursday or Friday.
I located a citation online, from a 2013 Lawrence Livermore National Laboratory piece on Semi-trailer boat tails, starting on page-12 from the top of the report.
Of special interest is 'Tail 2' a straight, 11-degree EBLA tail, top and sides, with horizontal floor.
Tail 2 produced the lowest Cd of four tails tested, @ delta-26% for a 48" , 3-sided tail, and delta-26.1%, for a 32", 4-sided tail.
If extrapolated to full-length, Tail 2 would be 263.3" in total boat-tail length, longest of the four.
The trailer's 'box' was only streamlined, starting with a wake of 80.75-sq-ft, and reducing to 67.372-sq-ft/ 62.19-sq-ft, respectively; a 16.56% / 22.97% wake reduction, respectively.
Qualitatively, a 4-sided, 48" tail would provide a delta 36.2% Cd.
It's worth a 'long' look!https://www.energy.gov/sites/prod/fi...ari_2013_o.pdf
File Type: pdf vss006_salari_2013_o.pdf (919 Bytes, 10 views)
The Following 3 Users Say Thank You to aerohead For This Useful Post:
JohnForde (07-26-2024), JSH (07-25-2024), Piwoslaw (07-25-2024)
