Old 07-31-2024, 02:05 PM   #3 (permalink)
Logic
Dont forget you also get a small amount of Vaporized sulfuric acid in that stream. Not much but enough to start corrosion. Definitely enough to mess with intake sensors.
Might that cause problems? Maybe, maybe not
Also Sulfur Hydroxide IIRC. (rotten egg smell but highly combustable IIRC)
I think maybe the bubbler will help with this. Especially if the bubbles are kept underwater for a while with baffles of some sort or those stones used in fishtank bubblers.
Also there is no reason one couldn't inject the gas after the airflow meter.
Especially as you don't want to be metering fuel into a gas that already contains fuel...
The fact is I don't know. Which is why I hoped someone here might be doing this!?
